Clearpass Guest MAC caching - cannot connect again from the same device
  • 1.  Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 09:34 AM
    I am testing Clearpass guest with MAC caching and self-registration.  I have been using an iPad to test.  I have followed the setup using the Clearpass Workshop Series
    The guest mac caching is working now since I added "Allow All MAC Auth" to the authentication method.  Now when I test with my iPad, after the account expires, I cannot re-connect to my guest SSID unless I delete the iPad from the endpoint's database.  Is there a way to delete the endpoint from the database after the account has expired or is there a better way that I am missing?
  • 2.  RE: Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 09:39 AM
    In your enforcement policy remove the amount of unique-devices per user allowed
  • 3.  RE: Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 09:54 AM
    Victor,
    Thanks for the quick response.  Do you mean under the "Role"?
  • 4.  RE: Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 10:07 AM
    You can either increase the amount of unique devices allowed per user or remove the rule if you think that enforcement is not needed
  • 5.  RE: Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 12:09 PM
    Hmm, I took it out of the role completely and it still won't let my iPad on.  I wouldn't expect it to be an issue with unique device count since I'm using the same device repeatedly, correct?
  • 6.  RE: Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 12:12 PM
    Are you using different names every time you register?
  • 7.  RE: Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 01:09 PM
    What do you see in access tracker when your authentication fails ?
  • 8.  RE: Clearpass Guest MAC caching - cannot connect again from the same device
    Posted Oct 02, 2017 02:20 PM
    I think I may have found the issue.  I checked access tracker and the client was getting assigned the [Guest] role instead of getting the default [Deny Access Profile].  I removed the second condition on the Enforcement Profile and that forced the client to get the Deny Access Profile and get now it gets the Captive Portal Page.Capture.JPG
