Clearpass Guest Manage Devices remove print icon
  • 1.  Clearpass Guest Manage Devices remove print icon
    Posted Apr 08, 2020 09:53 AM
    I used this topic to remove the print options in an operator profile
    https://community.arubanetworks.com/t5/Security/How-to-remove-the-print-option-from-operators/td-p/226731
    by adding
    <div>
    <form name="print_templates_form" style="display: none">
    </form>
    </div>
    in the footer of the form and the list views  the operator profile is using but it does not remove the print icon when you select a device in  Manage Device view
    Inspect shows the item to be in the mac_list_action_row_print form but adding
    <form name="mac_list_action_row_print" style="display: none">
    </form>
    to the footer of the mac_list view does not work
    These forms and views are used for MPSK zo there's no need for printing receipts.
    Can anyone help out?
    thanks
    Erik
  • 2.  RE: Clearpass Guest Manage Devices remove print icon
    Posted Apr 10, 2020 12:35 AM
    I don't see an easy way to remove/hide the print option since the mac_list form is not exposed in the UI.
    You may try removing permission to the operator under each print templates. This will not remove/hide the print option, just don't show print templates selection when you click on it (in a way prevent print option).
  • 3.  RE: Clearpass Guest Manage Devices remove print icon
    Posted Apr 11, 2020 02:19 PM
    Each of those actions has a common ID selector.
    Add this into the Header HTML or Footer HTML of mac_list and/or guest_users Views.
    {literal}<style type="text/css">
    #guest_users_action_row_print, #mac_list_action_row_print {
    display:none;
    </style>{/literal}
  • 4.  RE: Clearpass Guest Manage Devices remove print icon
    Posted Apr 14, 2020 03:22 AM
    thanks for that. Just what I was looking for.
    Most of them are linked to rights in the operator profile but would like to know if there is a list of common ID's available for the different icons?
    thanks,
    Erik
  • 5.  RE: Clearpass Guest Manage Devices remove print icon
    Posted Apr 14, 2020 08:36 AM
    If you right-click and Inspect, which I think most browsers have now, you can see them.  The ID follow:
    '#' + view name + '_action_row_' + ACTION
    Where ACTION is one of:
    Devices:
    • change_expiration
    • remove
    • edit
    • sessions
    • print
    • details
    Guest extras:
    • reset_password
