Hello
We got this custumer with some crazy requirments for their captive portal with clearpass...
She wants the fallowing:
1-No staff intervention for registration(we can do that with selft register no issue)
2-The Wifi will just work for 1 hour(i can put the 1 hour expiration but then he can just re register again) here is where i encounter the first issue
3-If the client order something else to eat(somehow you can re enable his access to the wifi) i dont think you can do that without their staff intervention)
Any idea how can i do most of those things?
If somehow i can put that they can use the internet for 1 hour and they can no longer use it in the day that could work... unless the client come back again to drink another coffee could happen...
If you guys had a client whit this requirments... what would you advice them??
Cheers
Carlos
