Clearpass Guest Reception account expiration
  • 1.  Clearpass Guest Reception account expiration
    Posted Apr 21, 2017 07:13 AM
    Hello Airheads
    Is there a way to restrict which account expiration and lifetime options are shown to a specific Clearpass Guest admin user, for example
    reception users can only create guest accounts that are valid for 8 hours
    admin users can create gut accounts valid for 8 hours, 24 hours, 7 days etc.
    I've tried searching and can't find anything that does exactly what I want, but I may have not been searching for the right options.
    thanks
  • 2.  RE: Clearpass Guest Reception account expiration
    Posted Oct 08, 2018 06:26 AM
    Hi.
    You have to:
    1. Go to Configuration / Pages / Forms & Views
    2. Duplicate for example "create_multi"
    3. Customize your newly created form by clicking "Edit Fields".
    4. When you are done customizing your fields go to Administrator / Operator Logins / Profiles and edit for example "Receptionist".
    5. Scroll down to the check box "Customization" and click to "Override the application's forms and views".
    6. Select the drop down box "Create Multiple Guest Accounts" and select you new form that you created in step 2.
    7. Done
    Have a great one!
    Petter
