Clearpass Guest repository format
  • 1.  Clearpass Guest repository format
    Posted Nov 16, 2013 05:15 AM
    Does anyone know what format the guest database on Clearness is. Can this be queried using LDAP queries from other devices? I have a colleague that would like to explore the possibility of writing an app to query the guest user repository and process the results.
  • 2.  RE: Clearpass Guest repository format
    Posted Nov 16, 2013 07:07 AM
    It cannot be queried using LDAP, but a read-only copy can be made available over SQL by setting the appexternal password by going to Administration> Server Configuration> Cluster-Wide Settings> General> Appexternal password.  Any SQL program like pgadmin will be able to query it with the username appexternal and whatever password is set there.
  • 3.  RE: Clearpass Guest repository format
    Posted Nov 16, 2013 11:13 AM
    Does changing that password impact any internal ClearPass processes or is
    it exclusively for external access?
  • 4.  RE: Clearpass Guest repository format
    Posted Nov 16, 2013 12:53 PM
    It will have no affect on ClearPass unless you have a split cluster design, where you have used appexternal account and password to gather information from the other cluster.
    Keep in mind this account has limited access to the database.
