ClearPass - Guest Self-Provisioning Cert Issue
  • 1.  ClearPass - Guest Self-Provisioning Cert Issue
    Posted Dec 10, 2014 04:43 PM
    After guests attach to the Guest SSID they are redirected to ClearPass for the employee sponsorship piece.  When the redirection happens the guest is prompted with a cert warning (general warning saying 'click here to proceed (not recommended)'.  When proceeding to the self-registration page it works just fine, however I'm looking for a way to elminate the cert from the equation.  I noticed that the guest is redirected to internal data plane IP of the ClearPass server via HTTPS. Is there a way to redirect to the hostname?  Guests aren't going to our internal IP's and will always get cert errors in the process.  Trying to make this as streamlined as possible.
  • 2.  RE: ClearPass - Guest Self-Provisioning Cert Issue
    Posted Dec 10, 2014 04:56 PM
    You can configure your captive portal profile on the controller to not require HTTPS and also configure CP Guest to do the same.   Alternatively you can install a publically trusted certificate.
    Controller:
    aaa authentication captive-portal "<Your-CP-Profile>"
       protocol-http
       login-page "http://hostname/guest/guest_page.php"
    ClearPass Guest:
    Configuration --> Authentication
  • 3.  RE: ClearPass - Guest Self-Provisioning Cert Issue
    Posted Dec 10, 2014 05:28 PM
    You are amazing.  Works like a champ.  THANK YOU for the quick response!!
