ClearPass Guest Self Registration and Sponsorship, multiple sponsor email addresses
This thread has been viewed 16 times
  • 1.  ClearPass Guest Self Registration and Sponsorship, multiple sponsor email addresses
    Posted Aug 24, 2017 07:10 PM
    We have ClearPass configured for Guest Self Registration requiring sponsorship approval in the form of an email address sent to the sponsor (as populated by the guest user in the self-registration form)
    We would also like the sponsorship email to be cc’d to a fixed email address also e.g. reception@12345.com
    Have been unable to work out how this can be done.  Any advice great appreciated.
  • 2.  RE: ClearPass Guest Self Registration and Sponsorship, multiple sponsor email addresses
    Posted Aug 28, 2017 04:25 AM
    You can configure that in the Sponsorship Confirmation:
    You can find this section in the 'Advanced Configuration' of your self-registration page.
  • 3.  RE: ClearPass Guest Self Registration and Sponsorship, multiple sponsor email addresses
    Posted Aug 28, 2017 07:28 PM
    Thanks Herman, worked a treat.  I had seen that setting but read it that the guest receipt would also be sent to this email.  Not the request for sponsorship.
    John
  • 4.  RE: ClearPass Guest Self Registration and Sponsorship, multiple sponsor email addresses
    Posted Apr 22, 2019 04:10 AM
    Hi John,
    I have same issue. Could you fix it?
  • 5.  RE: ClearPass Guest Self Registration and Sponsorship, multiple sponsor email addresses
    Posted Apr 28, 2019 05:08 PM
    Hi Ratchapas,
    Just need to follow Herman's instructions as above
    Send Copies:  Always send using BC
    Copies To:  reception@12345.com
    Cheers
    John
  • 6.  RE: ClearPass Guest Self Registration and Sponsorship, multiple sponsor email addresses
    Posted Jul 12, 2019 09:18 AM
    Hey! I just want to achieve the same and I set it up like Herman wrote. But it is not working as expacted.
    Clearpass is sending out the email to the sponsor email address which is configured in the sponsor_email field. There is no email send (sponsoring request) out to the email address which I configured in the "cc/bcc" field.
    After I click the link in the sponsoring mail which was sent out to the fixed sponsort email address I'll get an email in the inbox of the "cc/bcc" email address with the guest reciept.
    Tim wrote in a post that you can achieve this by using a distribution list. But I don't know how. Can anyone give some advise how to do this!?
    Thanks in advance
