I am mostly using the default guest self registrtion page and it works great, except the email receipt page shows (Aruba) for the SSID and in the instructions to connect. Do I need to manually edit the html for this to work correctly?
Can you give me more details? I have tried to find the correct field and I can't seem to find it. I would assume that it would pull the essid information automatically. Do you have to manually enter the information.
Here is one location or you can hard code it in the recipt page.
Thanks for the help.
