ClearPass Guest Session-Timeout Configuration
This thread has been viewed 24 times
  • 1.  ClearPass Guest Session-Timeout Configuration
    Posted Oct 08, 2018 12:46 PM
    I would like to set the time limit of how often a guest user needs to reauthenticate via captive portal.  For instance, a device should not have to reauthenticate via captive portal more than once in a 24 hour period.  I see many different possible settings and I'm confused on what each one controls.
    In ClearPass Enforcement Policies:
    1.  RADIUS - Session-Timeout
    2.  Session-Check - Allowed-Duration
    3.  Endpoint - MAC_Auth_Expiry (Now Plus X hrs)
    On Wireless Controller:
    1.  aaa policy - user-idle-timeout
    What is the difference between all of these settings and which ones are actually required to accomplish what I want?
    I heard that there is a 12 hour max for this setting for captive portals, is this true?
  • 2.  RE: ClearPass Guest Session-Timeout Configuration
    Posted Oct 08, 2018 12:49 PM
    This is handled by MAC caching and is pre-configured when you use service template.
