Clearpass guest skin manual
  • 1.  Clearpass guest skin manual
    Posted Apr 16, 2017 01:44 PM
    Does aruba has a manual on this?
    Let say i would like to build my own skin  for cleaprass guest, or also if i got one already made by Aruba and i would like to modify it, it is possible?  like chaning logos, colors and stuff like that.
    Cheers
    Carlos
  • 2.  RE: Clearpass guest skin manual
    Posted Apr 16, 2017 04:54 PM
    There’s no documentation really. It’s just HTML.
    Logos and colors can easily be modified in the skin settings. If you need modifications to a custom skin built by Aruba, open a TAC case to initiate the process.
  • 3.  RE: Clearpass guest skin manual
    Posted Apr 17, 2017 07:54 PM
    Can you import styles from a CSS sheet? if we have limited licenses for fonts/styles, can we reference an external CSS sheet?
    #AirheadsMobile
  • 4.  RE: Clearpass guest skin manual
    Posted Apr 25, 2017 11:58 AM
    Carlos, do you have access to Arubapedia for partners, if yes, there is an article on How-To: Custom Skin ClearPass Guest.
    but Tim is correct, it is HTML in the end...
  • 5.  RE: Clearpass guest skin manual
    Posted Apr 26, 2017 07:25 PM
    Thank man ill check on that!
  • 6.  RE: Clearpass guest skin manual
    #AirheadsMobile
