ClearPass Guest SMARTY configuration
  • 1.  ClearPass Guest SMARTY configuration
    Posted Sep 12, 2018 05:00 AM
    Hi, couple of questinos about using SMARTY in a clearpass guest environment.
    1). we hada a requirement to provide a simple guest login page that allowed a user to register game console mac addresses . and nothing else. We also wanted to use a specific URL so the user didn't have to use the standard clearspass one.
    With help from this list, what we ended up with was
    {if $smarty.server.SSL_TLS_SNI == 'mydevicesxb.york.ac.uk'}
    <meta http-equiv="refresh" content="0;url=https://mydevicesxb.york.ac.uk/guest/mac_create.php">
    {else} <meta http-equiv="refresh" content="0;url=http://clearpass8.york.ac.uk/tips/welcome.action">
    {/if}
    and it works just fine. Whatever the user types in gets you to a mac_create page and after a configuration you get a config receipt displayed.
    We now want to expand on this by allowing a "Manage Devices" link to work ( which is also avaiable from the receipt page as a link displaying the mac address being registered.
    Can't get thi to work, whatever I do gets me back to a login page and then mac_create.
    I thought the following would work in my web login script ( well actually the nested if should check for "contains" and not "eq")
    {if $smarty.server.REQUEST_URI eq "/guest/mac_list.php"}
    <meta http-equiv="refresh" content="0;url=https://mydevicesxb.york.ac.uk/guest/mac_list.php">
    {/if}
    {/if}
    ...but it doesn't
    any help appreciated
  • 2.  RE: ClearPass Guest SMARTY configuration
    Posted Sep 12, 2018 07:02 AM
    Sorted!
    Helps if you configure youtr Guest/Admin .Operator Profile to actually have access to the manage devices option :-(
