ClearPass Guest SMS Carrier
  • 1.  ClearPass Guest SMS Carrier
    Posted Jul 18, 2016 08:23 AM
    hi all,
    I try to configure a guest self registration page with a auto send SMS service. The SMS will be send via a customSMTP to SMS gateway.
    The problem is, that the mobile number which is entered is cut but the system (clearpass) so that the leading "0" or "+" is missing in the send out request. I can see that on the SMS gate which is unable to send out the SMS.
    I tried a couple of things like creating a custom carrier service with setting an country code etc. unfortunately without an success. The leading "0" or "+" will be cut off. It looks like that the option I choose in the carrier template will not be used.
    To make things clearer:
    this is a number how it should look like: 015112345678
    what it acutally looks like: 15112345678
    Right now I'm using CPPM 6.6.0.81015
    thanks in advance
    p.s.: it looks like another (german) had the same problems a while ago:
    http://community.arubanetworks.com/t5/AAA-NAC-Guest-Access-BYOD/ClearPass-Guest-SMTP-to-SMS-delivery-problems/td-p/71500
  • 2.  RE: ClearPass Guest SMS Carrier
    Posted Aug 23, 2016 04:27 PM
    Can you verify what your CPGuest > Config > SMS Services > Gateways > (edit yours) > Mobile Number Settings looks like?
