Clearpass Guest SMS questions
  • 1.  Clearpass Guest SMS questions
    Posted Jul 17, 2013 04:19 PM
    Is anyone using the SMS gateway feature to send credentials out? If so, who are you using and do you have any advice for us as we look to implement this functionality?
  • 2.  RE: Clearpass Guest SMS questions
    MVP
    Posted Jul 30, 2013 03:09 PM
    The easiest way and most cost-effective way (because it's free) is to use SMS over SMTP and send the texts through wifi. Once you choose this option you will have to setup an SMTP server, and define which mobile phone carriers you want to offer as an option on the captive portal form. This is how I have experienced setting up SMS for guest registration.
    Hope that helps.
  • 3.  RE: Clearpass Guest SMS questions
    Posted Aug 01, 2013 10:52 AM
    Is there any documentation on this?  I've searched but haven't found anything on specifically SMS over SMTP.
  • 4.  RE: Clearpass Guest SMS questions
    MVP
    Posted Aug 01, 2013 11:34 AM
    I would try checking out the ClearPass Guest deployment guide and do a search for "SMS"
    http://support.arubanetworks.com/DOCUMENTATION/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=10987
