ClearPass Guest SOAP interface
  • 1.  ClearPass Guest SOAP interface
    Posted Nov 06, 2013 02:44 PM
    I'm trying to use the ClearPass SOAP interface but am running into a few issues.
    I am coding in VB.NET and have imported the Service Referance from my ClearPass Guest as https://10.21.4.4/guest/soap_guestmanager.php?wsdl
    I am able to use the Referance in my VB project and followed the guide to setting up a basic command.  Using Ping as an example i am getting an error complaining about "GET" used instead of "POST".
    Does anyone have any ideas?
    VB Code
      Private Sub Button1_Click(sender As Object, e As EventArgs) Handles Button1.Click
            Dim client AsGuestManagerWebServiceClient = NewGuestManagerWebServiceClient
            client.ClientCredentials.UserName.UserName = "CaptivePortal"
            client.ClientCredentials.UserName.Password = "xxx"
            Dim PingRequest As New EmptyType()
            Dim PingResponse As New ResultType()
            ServicePointManager.ServerCertificateValidationCallback = New RemoteCertificateValidationCallback(AddressOf CertificateValidationCallBack)
            PingResponse = client.Ping(PingRequest)
            MsgBox(PingResponse.error)
        EndSub
        Function CertificateValidationCallBack( _
    ByVal sender AsObject, _
    ByVal certificate As X509Certificate, _
    ByVal chain As X509Chain, _
    ByVal sslPolicyErrors As SslPolicyErrors _
    ) AsBoolean
            ReturnTrue
        EndFunction
    App.Config
    <?xml version="1.0" encoding="utf-8" ?>
    <configuration>
        <startup>
            <supportedRuntime version="v4.0" sku=".NETFramework,Version=v4.5" />
        </startup>
        <system.serviceModel>
            <bindings>
                <basicHttpBinding>
                  <binding name="GuestManagerSoapBinding" closeTimeout="00:01:00"
                           openTimeout="00:01:00" receiveTimeout="00:10:00"
                           sendTimeout="00:01:00"
                           allowCookies="false" bypassProxyOnLocal="false"
                           hostNameComparisonMode="StrongWildcard"
                           maxBufferSize="65536" maxBufferPoolSize="534288"
                           messageEncoding="Text" textEncoding="utf-8"
                           transferMode="Buffered"
                           useDefaultWebProxy="true">
                    <security mode="TransportCredentialOnly">
                      <transport clientCredentialType="Basic"
                                 proxyCredentialType="Basic"
                                 realm="" />
                      <message clientCredentialType="UserName" algorithmSuite="Default" />
                    </security>
                  </binding>
                    <binding name="GuestManagerSoapBinding1" />
                </basicHttpBinding>
            </bindings>
            <client>
                <endpoint address="http://10.21.4.4/guest/soap_service.php"
                    binding="basicHttpBinding" bindingConfiguration="GuestManagerSoapBinding"
                    contract="GuestManager.GuestManagerWebService" name="GuestManagerWebServicePort" />
            </client>
        </system.serviceModel>
    </configuration>
    Error on ClearPass Guest is:
    Invalid SOAP request: HTTP method 'GET' is not POST
    Client:    10.21.7.182:51038
    Script:    /guest/soap_service.php
    Function:  NwaSoapServiceMain
    Arguments: array (
      'soap_action' => 'amigopod.guest.ping',
    Details:   array (
      'headers' => array (
        'CONTENT_TYPE' => 'text/xml; charset=utf-8',
        'HTTPS' => 'on',
        'HTTP_ACCEPT_ENCODING' => 'gzip, deflate',
        'HTTP_CONNECTION' => 'Keep-Alive',
        'HTTP_HOST' => '10.21.4.4',
        'HTTP_SOAPACTION' => 'amigopod.guest.ping',
        'HTTP_USER_AGENT' => '',
        'HTTP_VSDEBUGGERCAUSALITYDATA' => 'uIDPo+RJgjmioWlGhettZ7ao/0QAAAAAaKv3ioWXQ0KCdRf4d8032IGcwbYuOQxFuyE8923pqb0ACQAA',
        'PHP_SELF' => '/guest/soap_service.php',
        'QUERY_STRING' => '',
        'REMOTE_ADDR' => '10.21.7.182',
        'REMOTE_PORT' => '51038',
        'REQUEST_METHOD' => 'GET',
        'REQUEST_TIME' => 1383766304,
    Thanks!
  • 2.  RE: ClearPass Guest SOAP interface
    MVP
    Posted Apr 17, 2014 05:00 AM
    Did you ever get this issue fixed Eric?
  • 3.  RE: ClearPass Guest SOAP interface
    Posted Feb 13, 2015 08:34 AM
    Hi, noticed this post and have a similar problem (?). I just dipping my toes in the water here and my code is not half as fancy as the sample above - I'm using powershell. However, I end up with the same error message "Invalid SOAP request: HTTP method 'GET' is not POST" . If someone can spot my (obvious) mistake, I would really appreciate your input!
    /F
    $user = "user"
    $pass = "password"
    $pair = "$($user):$($pass)"
    $bytes = [System.Text.Encoding]::ASCII.GetBytes($pair)
    $base64 = [System.Convert]::ToBase64String($bytes)
    $basicAuthValue = "Basic $base64"
    $headers = @{ Authorization = $basicAuthValue }
    Invoke-WebRequest "http://server_ip/guest/soap_guestmanager.php" -Headers $headers -ContentType "text/xml" -InFile C:\Temp\xmlin.txt -OutFile c:\Temp\xmlout.txt -Method Post
