ClearPass Guest User Fields / Variables
  • 1.  ClearPass Guest User Fields / Variables
    Posted Aug 12, 2022 08:12 AM
    Hello everyone!
    I've been playing around with using some of the Guest User fields in ClearPass to forward some information, and one thing has been bugging me.
    Generally in ClearPass we can use variables referencing the connection, authentication, and authorization sources, but in some examples we see references directly to the database.
    Such as with Guest User when we update fields I've seen examples with both cases below. Same as for Endpoints. Now, it seems to me that the first example is a reference to the SQL Authentication source, which is filtered to specific attributes. The second example references the dictionary attributes directly.
    %{Authorization:[Guest User Repository]:xxxxxx}
    %{GuestUser:XXXXXX}
    In essence both seem to access the same information. If this is true, why use the first example? Is it just to filter or alter the field through SQL before referencing it? What do you guys generally see in use?
    Cheers,
    RK
  • 2.  RE: ClearPass Guest User Fields / Variables
    Posted Aug 17, 2022 04:17 AM
    I've seen either in use. I believe there are similar cases where the short name (GuestUser) is filled by other sources if there is nothing in the 'raw' (Authorization:[Guest User Repository]) source. Either should work in general, and I don't have a big preference for one or the other.
  • 3.  RE: ClearPass Guest User Fields / Variables
    Posted Sep 07, 2022 06:27 AM
    Thanks for the input Herman!
    Sincerely,
    RK
