ClearPass Guest with AD integration with Cisco WLC
  • 1.  ClearPass Guest with AD integration with Cisco WLC
    Posted Sep 04, 2018 07:49 AM
    Hi All,
    I am having issues authenticating AD users via guest portal. The setup is:
    - Cisco WLC based guest network
    - ClearPass based guest portal
    Self registration/guest authentication is working perfectly fine. On the Log in page, I have a hyperlink that says "Staff Login" and it takes the user to a web log in page created to authenticate staff members (Active Directory).
    Have tried on multiple AD accounts and user AD authentication through web login page is failing. I've tested same credentials through CPPM CLI and it worked fine.
    I have attached logs file and access tracket screenshot. Apprecaite your help here.
    CPPM version is: 6.7.4.107401
    WLC is: 8.2.166.0
    Attachment(s)
    txt
    Logs.txt   55 KB 1 version
  • 2.  RE: ClearPass Guest with AD integration with Cisco WLC
    Posted Sep 04, 2018 08:13 AM
    Use PAP
  • 3.  RE: ClearPass Guest with AD integration with Cisco WLC
    Posted Sep 04, 2018 08:43 AM
    Hi Tim,
    They have security concerns with PAP and insisted to use CHAP.
  • 4.  RE: ClearPass Guest with AD integration with Cisco WLC
    Posted Sep 04, 2018 08:44 PM
    Anythig else you can recommend?
  • 5.  RE: ClearPass Guest with AD integration with Cisco WLC
    Posted Sep 05, 2018 09:37 AM
    Use MSCHAP/v2 (if you can) insted of CHAP. MSCHAP will work against AD.
