Clearpass Guest with mac caching and Cisco WLC
  • 1.  Clearpass Guest with mac caching and Cisco WLC
    Posted Jan 23, 2015 04:41 PM
    Checking to see if anyone else has seen this type of issues with Cisco WLC & Clearpass guest:
    I have setup an open guest wlan on a Cisco WLC with Layer2 mac-filtering , Layer3 Web Policy/"On Mac failure" pointing to external ClearPass captive portal.
    I used the templates to create the 2 services,
    -one with mac authentication accept if exists, reject if doesn't exist
    -WLC receives reject and sends user to Clearpass portal page to accept terms.
    -CPM radius reject delay is set to 0
    -The first time a user connects, the clearpass portal appears
    -user accepts terms,
    -instead of gaining access the Cisco internal web auth page appears.(no attributes set on endpoint)
    -user refreshes the browser, the Clearpass screen appears.
    -user accepts terms and gains access (attributes are set on endpoint)
    This can easily be reproduced. I've opened a Cisco TAC but waiting to work on it with them.
    Jeanne
  • 2.  RE: Clearpass Guest with mac caching and Cisco WLC
    Posted Jan 23, 2015 05:29 PM
    Can you please share the error message if any ?
    Which attributes are you trying to use ?
  • 3.  RE: Clearpass Guest with mac caching and Cisco WLC
    Posted Jan 23, 2015 06:02 PM
    The templates set 2 attributes:
    Guest Role ID
    Username(which, in this case is the same for all guest because just accepting a policy)
    There isn't an error, other than the reject when the user is connecting the first time and mac address isn't cached already.
    To do a retest, we just clear the 2 attributes and can reproduce the problem.
    thanks
    Jeanne
  • 4.  RE: Clearpass Guest with mac caching and Cisco WLC
    Posted Jan 24, 2015 12:43 AM
    What Version WLC?
    You need to consider doing it with Central WEB auth. (Like ISE). I hated doing to with the on-Mac-failure.
