ClearPass Guest with OnGuard health check
This thread has been viewed 24 times
  • 1.  ClearPass Guest with OnGuard health check
    Posted Jan 17, 2023 06:57 AM
    Hi folks,
    I've an enormous challenge to implement OnGuard health check within the ClearPass Guest portal.
    The Guest Portal itself is working fine, also with mac caching.
    When enabling health check, the check is starting, health is oke, but the check is starting all over.
    Or when changing my anounymous check cannot be found or password not correct.
    I followed the template steps.
    My wireless environment is a wireless controller cluster with 20 AP's.
    Next challenge is to add the same health check to a PSK SSID. I added the ClearPass servers as authentication servers, added roles, but getting the same loop in Onguard.
    Does the primary usage be employee or guest or doesn't matter?
    My ClearPass is running 6.10.8
  • 2.  RE: ClearPass Guest with OnGuard health check
    Posted Jan 17, 2023 05:07 PM
    when you get the onguard loop, what does the posture info look like in Access tracker , is posture status = unknown?
  • 3.  RE: ClearPass Guest with OnGuard health check
    Posted Jan 18, 2023 03:00 AM
    posture status is healthy... logging on...
    Reject message from the anounymous user configured in the guest web login page.
    No service matched.
    I can't understand that because I configured this with a template so the basics should work I suppose.
  • 4.  RE: ClearPass Guest with OnGuard health check
    Posted Jan 18, 2023 06:18 PM
    in your enforcement profile, have you enabled "use cached results" ?
  • 5.  RE: ClearPass Guest with OnGuard health check
    Posted Jan 19, 2023 03:11 AM
    Yes I have...
  • 6.  RE: ClearPass Guest with OnGuard health check
    Posted Jan 19, 2023 10:05 AM
    Hi, can you share the WebAuth service?
