last person joined: 3 hours ago
Clearpass HA questions
  • 1.  Clearpass HA questions
    Posted Mar 23, 2023 10:43 AM
    Hello! i got a few questions regarding this
    The configuration seems easy.
    But i want to know a few details
    Right now we have one clearpass that is on production and the other one which is there just waiting to be the subcriber
    1-Do i need to join in the domain the subcriber first before making it the subcriber?
    2-I installed the Radius Eap certificate before making it that clearpass as a subcriber, i saw that you did it after, there is no issue if i leave it like that?
    3-I need to create the virtual IP and  change all the switches radius server ips to the virtual ip address, the same will be for the wirleess controller, i need to change the ip it has for the virtual ip address
    4-i need to change the captiveporta.domain.com entry on the dns server for the guest users to use the virtual ip.   For this guest vmodule to totally work i will need to have at least one publisher up
    If you think on any other recommendation please advise me thanks
  • 2.  RE: Clearpass HA questions
    MVP EXPERT
    Posted Mar 23, 2023 12:10 PM
    1) Each CPPM will need to be joined to the domain regardless as to whether it is a Publisher or Subscriber. You can do this before promoting/demoting a Publisher/Subscriber.
    2) No, the certificates are independent to each CPPM and will survive the Publisher/Subscriber transistion.
    3) You can send RADIUS requests to the any interface on CPPM and it will respond. Your design will determine if the switch/controller sends it to MGMT/DATA/VIP.
    4) This is correct, the HTTPS certificate should also match this domain too.
    I suggest you take a look at the cluster guidelines.
  • 3.  RE: Clearpass HA questions
    Posted Mar 23, 2023 12:36 PM
    Okay
    Do you suggest that i add this new clearpass before doing the HA.  It just that i didnt got that part.  Sorry my english is not that good
    Just want to know if i add this before creating the cluster or after creating the cluster
    Right now just the clearpass in production is joined in the AD
  • 4.  RE: Clearpass HA questions
    MVP EXPERT
    Posted Mar 23, 2023 12:47 PM
    Yes, you will need to add the Subcriber before setting up HA. It can be join to the domain either before or after this process.
  • 5.  RE: Clearpass HA questions
    Posted Mar 25, 2023 10:52 AM
    Thank you Craig!
