Clearpass How can i add a IETF Attribute
  • 1.  Clearpass How can i add a IETF Attribute
    Posted Mar 10, 2015 05:59 AM
    Hi
    we got some new HP/3Com bladeswitches and I am trying to get Radius authentication via ssh working with CPPM.
    During some research i found the attributes which must be send from Radius server to the switch.
    One of them is Standard Radius Login-Service (15) Attribut with the Value of 50 (ssh).
    In the dictiononary this attribut with value of 50 does not exist.
    I know that it is not a standard ietf attribute but on lots of radius server you can add it manually:
    http://hpnetworkers.blogspot.co.uk/2011/05/hp-series-h3c-comware-radius.html
    Is it possible on CPPM too?
    Thanks for help.
  • 2.  RE: Clearpass How can i add a IETF Attribute
    Posted Mar 10, 2015 07:02 AM
    You would need to export the radius dictionary, modify the XML to add the new entry and then reimport it.
    Tim
  • 3.  RE: Clearpass How can i add a IETF Attribute
    Posted Mar 10, 2015 08:09 AM
    <post removed>
  • 4.  RE: Clearpass How can i add a IETF Attribute
    Posted Mar 10, 2015 08:43 AM
    Thanks exporting and editing was the solution. sometimes it is more easy than expected.
  • 5.  RE: Clearpass How can i add a IETF Attribute
    Posted Dec 04, 2015 10:22 AM
    Administration -> Dictionaries -> RADIUS
    Find "IEFT" in the list for Vendor Name. Clik on "IEFT".
    Click on "Export" and save the XML file.
    Open the XML file and search for "Login-Service"
    Add this line under existing enumOrdinal(s):
    <ValidValue enumOrdinal="50" value="SSH"/>
    Save the updated XML file.
    Now import the updated Radius dictionary file for IEFT.
    Administration -> Dictionaries -> RADIUS, click on Import in upper right corner.
    Find the updated XML file, and clik on Import.
    Now you are able to add Radius:IEFT Login-Service = SSH (50) for the Enforcement profile.
    If you choose to use Telnet (0) for Login-Service, then both Telnet and SSH access is accepted (if the switch have both Telnet and SSH service enabled).
    If you, however, use SSH (50) for Login-service only, then Telnet access is rejected.
    Finally add the Radius:Huawei Huawei-Exec-Privilege = 3 to the Enforcement profile, if you want access level as administrator (highest), when login is accepted.
    Management login for Radius on the HP Comware switch is enabled by:
    domain <name>
    authentication login radius-scheme <name of radius scheme>
    authorization login radius-schme <name of radius scheme>
