Network Management
Clearpass in Airwave remains down
  • 1.  Clearpass in Airwave remains down
    MVP
    Posted Apr 28, 2017 09:01 AM
    So I have configured our Clearspass servers with snmpv3 details. Configured the same credentials (several times) in Airwave thinking it should at least be able to tell the servers are up/down and some memory/cpu stats.
    Unfortunately no matter what I do, I cannot get those CPPM's to register as up in Airwave. They stay down.
    Configuring the same in IMC and I get immediate respons and am abe to snmp walk the server, so my snmp (v3) config seems correct.
    Anybody got a clue what I might be missing here?  Or how to troubleshoot?
  • 2.  RE: Clearpass in Airwave remains down
    Posted Apr 28, 2017 09:36 AM
    Have you tired using snmpv2 and checked the stauts? After configuring the details in CPPM, you haves selected  device type as Clearpass from Deivce Setup > Add drop downlist.?
    Pavan
  • 3.  RE: Clearpass in Airwave remains down
    MVP
    Posted Apr 28, 2017 09:44 AM
    Yes, snmpv2 does work, but you'll understand I'd like to use snmpv3 instead,
    Yes, I added the devices as Clearpass
  • 4.  RE: Clearpass in Airwave remains down
    Posted Apr 28, 2017 10:29 AM
    Checked in my lab, I am not able to add the device using snmpv3, it is timingout, it looks like a bug. As workaround for now use snmpv2.
    Pavan
    If my post addresses your query, give kudos:)
  • 5.  RE: Clearpass in Airwave remains down
    MVP
    Posted Apr 28, 2017 11:48 AM
    Thanks for checking.
    Does your confirmation mean Aruba techsup/engineering is investigating or should I still open a support case to get the ball rolling?
  • 6.  RE: Clearpass in Airwave remains down
    Posted Apr 28, 2017 11:50 AM
    Could you share me your contact details or if you have any old ticket opened. I will open new ticket and file bug.
    Pavan
  • 7.  RE: Clearpass in Airwave remains down
    Posted Apr 28, 2017 12:04 PM
  • 8.  RE: Clearpass in Airwave remains down
    Posted Apr 28, 2017 12:06 PM
    Koen,
    Could you please check the Group --> Basic page on Airwave where we have clearpass added and make sure we have SNMP Version: selected as V3 under Aruba section,
  • 9.  RE: Clearpass in Airwave remains down
    MVP
    Posted Apr 28, 2017 12:52 PM
    thats is more than likely it, but I'll have to check on Tuesday.
    I'll mark it as solved nonetheless. Thanks.
  • 10.  RE: Clearpass in Airwave remains down
    Posted Apr 28, 2017 12:23 PM
    Yes, please check the snmp setting in Groups>Basic page and check it. I tired, it works for me.
    Pavan
