last person joined: 5 hours ago
ClearPass Ingress Event Engine Testing
  • 1.  ClearPass Ingress Event Engine Testing
    Posted Dec 23, 2017 05:37 PM
    Ciao,
    I'm trying to create a new simple Ingress Events Dictionary without success. I attached my example. I'd like map IP and userID coming from syslog but the event generates is blank.
    Attachment(s)
    txt
    PAN-USERID.txt   2 KB 1 version
  • 2.  RE: ClearPass Ingress Event Engine Testing
    Posted Dec 23, 2017 06:41 PM
    Did you build a dictionary and map it to the event source?
  • 3.  RE: ClearPass Ingress Event Engine Testing
    Posted Dec 24, 2017 08:57 AM
    Yes I did.
    I started with a configuration worked (PAN FW sends threat log and CPPM uses CoA to change authorization). What I did has been:
    - Modify the dictionary in order to match a new syslog event;
    - Associated  the nre dictionary just created in Configuration--Network-Event Sources
    - Generare new syslog event and testing.
    For troubleshooting I checked .pcap and igesyslog.log the format of syslog event. It seem ok
    I check my matching rule in dictionary with http://grokconstructor.appspot.com/do/match. It seem ok
    What I've not able to do is troubleshooting regarding parsing of syslog.
