Hi guys i m trying create a bandwidth and session report from my clearpass insight for wifi user. Unfortunately my report status in error and cannot gab any information. But it working fine on other categories Just want to verify do we need aruba airwave in oder the generate bandwidth and session report on insight.
Have you got a screenshot of the error?
i am not sure need any additional setting on my ccpm
Do you have RADIUS accounting data being sent to CPPM? Is there any accounting sessions under Monitoring -> Live Monitoring -> Accounting?
i dont see any session on my accouting live monitoring
You will need to configure RADIUS Accounting on the authenticator device (e.g switch, WLC) to send RADIUS Accounting information to CPPM. This will allow for bandwidth utilisation stats etc to be recorded. This should generate data for the report in question. You can also enable the logging of interim accounting on CPPM to obtain accurate start stop information as well as how much bandwidth is consumed during the clients session.
Is there any guide for configure radius acconting for aruba wlc my current version is 8.4
The AOS 8.4 User Guide covers RADIUS Accounting (p210). In short, however you configure it under your AAA Profile.
aaa profile "test" radius-accounting "CPPM-Server-Group" radius-interim-accounting !
Thanks alot i will try it out later.
