Clearpass insightdb join auth & radius_acct tables with session_id
  • 1.  Clearpass insightdb join auth & radius_acct tables with session_id
    Posted Mar 24, 2020 02:48 PM
    I'm trying to access data in both the auth and radius_acct tables in the InsightDB however I am having an issue with the join.  In the auth table, the session_id is stored as a varchar however in the radius_acct the session is stored in a json array.
    Does anyone know how to create a join between these two tables with these columns?
    Example:
    select session_id from auth limit 1
    R00000000-08-5daac7ee
    select session_id from radius_acct limit 1
    {R01dfe002-12-5e7a3d5d,R03f6f208-11-5e7a3d21}
  • 2.  RE: Clearpass insightdb join auth & radius_acct tables with session_id
    Posted Mar 25, 2020 01:39 PM
    The radius_acct.session_id is a text array. To reference the first element you can user radius_acct.session[1]. And the second using radius_acct.session[2], etc
    I'm not great at SQL but this seems to work:
    SELECT * FROM auth
    JOIN radius_acct ON auth.session_id = ANY (radius_acct.session_id)
  • 3.  RE: Clearpass insightdb join auth & radius_acct tables with session_id
    Posted Mar 25, 2020 01:56 PM
    Thanks that did it, so easy
  • 4.  RE: Clearpass insightdb join auth & radius_acct tables with session_id
    Posted Apr 07, 2020 12:32 AM
    If the file is password protected, enter the password in the Enter secret for the file field TellPopeyes.
