ClearPass Integration to AD over Mobility Controller
  • 1.  ClearPass Integration to AD over Mobility Controller
    Posted Jan 17, 2023 10:47 AM
    Hi, I am new to Aruba ClearPass.
    Basically, what I want to achieve is to use ClearPass and RADIUS authentication for my wireless SSID connection. I have a multiple of Aruba APs that connected to the Aruba Mobility Controller. The APs are broadcasting 2 SSIDs which are 'Staff' and 'Guest". The ClearPass only using Access License at the moment.
    The diagram NetFlow is as follows:
    User --> SSID --> AP --> Mobility Controller --> ClearPass --> Active Directory
    What I want to do is the users can only connect to the Staff SSID if they are using Laptop or registered Laptop MAC address, not mobile phone nor any BYOD. This will be implemented in the ClearPass policies. After successfully connected to the Staff SSID, the user will have to enter their AD credentials in order to fully connected and have access to the network.
    Is there any full tutorials od documentation that I can refer to? I have problem on configuring the integration of AD into the ClearPass, then configure the Mobility Controller to use ClearPass as RADIUS server. Thank you.
  • 2.  RE: ClearPass Integration to AD over Mobility Controller
    Posted Jan 17, 2023 04:53 PM
    here you can find a lot of tutorials for Clearpass
    https://www.youtube.com/watch?v=bnOGv6sN804
