Clearpass integration with aruba introspect
  • 1.  Clearpass integration with aruba introspect
    Posted Jul 05, 2018 09:24 AM
    Can anyone provide configuration documents for integrating Aruba Introspect UEBA with Clearpass?
    Atleast, suggest the logic/tips on integration if no documentation available.
  • 2.  RE: Clearpass integration with aruba introspect
    Posted Jul 05, 2018 09:27 AM
    A public document has not yet been released.
  • 3.  RE: Clearpass integration with aruba introspect
    Posted Jul 06, 2018 09:33 AM
    Please work with your local Aruba IntroSpect SE to understand the use-case and get you started or the documents.
  • 4.  RE: Clearpass integration with aruba introspect
    Posted Jul 20, 2018 04:14 PM
    Do you have an IntroSpect AN setup? I can help you with the config if you have an immediate requirement. The TechNote is Work In Progress and should be available soon.
    The logic is simple
    1. ClearPass posts user/device context to IntroSpect using Endpoint Context server actions leveraging the APIs on IntroSpect.
    2. IntroSpect can Quarantine a risky user on the network leveraging the APIs on the ClearPass
