ClearPass Integration with Ivanti Endpoint Manager formerly LANDESK Management Suite
  • 1.  ClearPass Integration with Ivanti Endpoint Manager formerly LANDESK Management Suite
    Posted Jul 19, 2017 07:03 PM
    Teams,
    Please find information and details related to a new ClearPass Integration with Ivanti Endpoint Manager [EPM], you’ll likely know this product by its former more popular name, LANDESK Management Suite.
    LANDesk and a number of other s/w products merged under the brand Ivanti earlier this year. Products like AppSense and Shavlik should also be familiar to you.
    In this TechNote find out how via SQL we can utilise EPM as an authorization source. Working directly with Ivanti helped us understand the underlying SQL schema and how we could get access to pertinent endpoint data utilizing their internal identifiers. In the TechNote are several use-cases, many more are possible and the key to accessing the data which is equally dependent on the licensed modules of EPM is explained and hopefully provides the relevant guide and knowledge transfer to allow you to do more as your customers might demand additional use-cases.
    You can find the document on the support site located here https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=26123
    Happy reading – go fill your boots..!!….. comments and feedback/suggestions graciously accepted.
  • 2.  RE: ClearPass Integration with Ivanti Endpoint Manager formerly LANDESK Management Suite
    Posted Apr 11, 2019 08:04 PM
    It seems that this integration introduces a single point of failure for all authentications (even if only using Ivanti / Landesk as an authorization source). Am I correct here or is there any way to eliminate that?
  • 3.  RE: ClearPass Integration with Ivanti Endpoint Manager formerly LANDESK Management Suite
    Posted Apr 11, 2019 10:26 PM
    I was able to add some fault tolerance to this integration if anyone is in need:
    https://community.arubanetworks.com/t5/Security/External-Authorization-SQL-Timeout/m-p/526366
