Clearpass integration with ubiquiti
This thread has been viewed 30 times
  • 1.  Clearpass integration with ubiquiti
    Posted Dec 29, 2016 03:35 PM
    Has anyone by any chance, integrated clearpass guest with ubiquiti??
  • 2.  RE: Clearpass integration with ubiquiti
    Posted Dec 30, 2016 11:26 AM
    What specific features are you looking at?
  • 3.  RE: Clearpass integration with ubiquiti
    Posted Dec 30, 2016 11:27 AM
    captive portal with clearpass guest that allows you to integrate it with opera.
    They wish to change the nomadix to clearpass.
  • 4.  RE: Clearpass integration with ubiquiti
    Posted Dec 30, 2016 11:29 AM
    im also stuck onthe ubiquiti side The controller offers RADIUS only under WPA-Enterprise condition. We have set "External Portal Server" to point to the relevant registration page on the ClearPass (i dont see something to  redirect to any subdirectories, just to one IP).
  • 5.  RE: Clearpass integration with ubiquiti
    Posted Dec 30, 2016 11:31 AM
    Can you give me a week? I have a UniFI AP on the way.
  • 6.  RE: Clearpass integration with ubiquiti
    Posted Dec 30, 2016 11:38 AM
    yeah if you can give us if its possible it would be great!!
    There are many clients in our country that use unifi, and got nomadix
    They are not happy with nomadix and if we can make ubiquiti works with clearpass, we would be able to get in those accoutns with clearpass!
    Thanks Tim!!
    Cheers
    Carlos
  • 7.  RE: Clearpass integration with ubiquiti
    Posted Jan 03, 2017 02:05 PM
    Hey Carlos - I played with this a bit last night and I don't think it's something we can get working right now. They don't use a traditional client browser POST and they also do not support CoA. Please submit a feature request for this.
    Something else I noticed was that they don't support MAC-Authentication, so if we were to get the captive portal authentication to work, the user would have to re-authenticate everytime they disconnect and reconnect.
  • 8.  RE: Clearpass integration with ubiquiti
    Posted Jan 04, 2017 10:28 AM
    Thankss for your time Tim
    Cheers
    Carlos
  • 9.  RE: Clearpass integration with ubiquiti
    Posted Aug 14, 2018 08:15 PM
    Just wondering if there was an update on if Ubiquiti networks will work with ClearPass. I chatted sales today and they said that ClearPass was "network agnostic" and that it should work, but wanted to get your input.
  • 10.  RE: Clearpass integration with ubiquiti
    Posted Jul 24, 2020 04:35 AM
    Hello all,
    I need too information for Unifi AP integration in clearpass.
    Just wireless 802.1X connection for client
  • 11.  RE: Clearpass integration with ubiquiti
    MVP GURU
    Posted Jul 24, 2020 05:14 AM
    @liimp wrote:
    Hello all,
    it works
  • 12.  RE: Clearpass integration with ubiquiti
    Posted Jul 24, 2020 05:19 AM
    Ok but any How to available for this configuration ?
    what other features are supported ?
  • 13.  RE: Clearpass integration with ubiquiti
    Posted Jul 24, 2020 10:47 AM
    Can you share the config ?
  • 14.  RE: Clearpass integration with ubiquiti
    MVP GURU
    Posted Jul 28, 2020 04:32 PM
    No need specific configuration for 802.1x
  • 15.  RE: Clearpass integration with ubiquiti
    Posted Sep 22, 2020 09:14 AM
    Hola.
    Recién estoy haciendo la prueba con los Unifi y aun no logro que me autentique, alguna sugerencia de configuración?. Les agradezco mucho cualquier tip que me pueda brindar al respecto
  • 16.  RE: Clearpass integration with ubiquiti
    Posted Nov 26, 2018 12:24 PM
    Tim,
    Are you aware if any updates progress has been made on this intregration.  I am working on a deployment with a client currently and they would like to do a clearpass guest integration as well as dot1x wired and wireless on Ubiquiti and HPE switching.
    Any help here would be greatly appreciated.
  • 17.  RE: Clearpass integration with ubiquiti
    Posted Mar 22, 2019 12:16 PM
    Any updates on this integration? we have a scenario that we need to use ubiquiti gear and Radius Auth tieh clearpass
  • 18.  RE: Clearpass integration with ubiquiti
    Posted Mar 26, 2019 07:30 PM
    Looks like just a few weeks ago they added CoA support to the UniFi firmware, at least for 'Disconnect'
    https://community.ubnt.com/t5/UniFi-Feature-Requests/Implement-802-1x-Change-of-Authoirzation-CoA-support/idi-p/1762325
    802.1x RADIUS auth should already be supported, and it looks like somewhere along the way they added MAC Auth as well, because the options are in there. I don't have a ClearPass server at home where my UniFi gear is, so can't easily play with it.
  • 19.  RE: Clearpass integration with ubiquiti
    Posted Jun 19, 2019 06:25 PM
    I have RADIUS working between Unifi AP's and Clearpass, but struggling with Clearpass guest captive portal redirection. Anyone figure that out?
  • 20.  RE: Clearpass integration with ubiquiti
    Posted Aug 03, 2019 03:51 AM
    Hi Json,
    Can you tell me the exact step of ClearPass Integration with Unifi Wireless
  • 21.  RE: Clearpass integration with ubiquiti
    Posted Feb 05, 2020 03:28 PM
    Hi guys,
    Any update from Aruba on this case ? I have be recently asked to run PoC Ubiquity with Clearpass but I do not know if there is any point to do it since there was no support for url-redirect as per last post here.
    Is the CoA working at least ?
    Br
    Piotr
  • 22.  RE: Clearpass integration with ubiquiti
    Posted Apr 12, 2020 11:12 AM
    can you share the configuration please..
    I always get the error "Required parameters unavailable"
    thanks
  • 23.  RE: Clearpass integration with ubiquiti
    Posted Jun 14, 2018 05:20 PM
    I was wondering since it has been over a year, if anyone has been able to get ubiquiti and ClearPass to play nice.  Looking into getting a branch office that uses ubiquiti APs and switches to authenticate to our ClearPass server over a site to site VPN.  Has anyone made that work?
