Clearpass interrogating client certificate
  • 1.  Clearpass interrogating client certificate
    Posted Feb 05, 2016 11:49 AM
    I have been looking for advice on how to have Clearpass look for an existing certificate on a Windows 7 client as part of .1x authentication. I am successfully using AD group membership to allow SSO into our corporate SSID, but we also have a Workstation Authentication cert that all of our laptops get via self enrollment when they are added to the domain. I would like to verifiy this certificate exists.
    Looking for conceptual advice and specific direction on using this option.
    TYIA
  • 2.  RE: Clearpass interrogating client certificate
    Posted Feb 05, 2016 11:52 AM
    - Upload the root CA to ClearPass
    - Create a service using the EAP-TLS method
    - Configure the supplicant to use machine authentication with EAP-TLS
  • 3.  RE: Clearpass interrogating client certificate
    Posted Feb 05, 2016 12:03 PM
    So is this just adding my PKI server in Administration - Certificates - Trust List?
    I have a 1X service that is working. It does have EAP TLS as an Authentication Method:
  • 4.  RE: Clearpass interrogating client certificate
    Posted Feb 05, 2016 01:55 PM
    TYIA
    If you are trying to do username/password authentication for users (EAP-PEAP) and certificate (EAP-TLS) for computers, you cannot do that combination.  That is a limitation of the Windows Supplicant.  Both authentication needs to be EAP-PEAP or EAP-TLS.
  • 5.  RE: Clearpass interrogating client certificate
    Posted Feb 05, 2016 02:17 PM
    As I have been researching this today. I came across this document:
    http://community.arubanetworks.com/aruba/attachments/aruba/aaa-nac-guest-access-byod/9125/1/ClearPass-Win7-PEAP-TLS-v1.0-20140114.pdf
    and it looked like what you are describing since I could choose CHAP or Certificate on the Win7 side.
    What is best practice then, if I would like to verify machine and user?
  • 6.  RE: Clearpass interrogating client certificate
    Posted Feb 05, 2016 02:24 PM
    I'd recommend doing user and computer using PEAP controlled by GPO.
    Sent from Nine
