last person joined: 10 hours ago
ClearPass - Intune Compliance State -> Separate between configured policies
This thread has been viewed 19 times
  • 1.  ClearPass - Intune Compliance State -> Separate between configured policies
    Posted Jun 14, 2021 06:11 AM
    Is there a way for devices administered by Microsoft Intune to separate between configured compliance policies configured in Intune?
    For now it seems the only option is to use:
    Endpoint: Intune Compliance State     state     EQUALS     compliant/InGracePeriod/noncompliant
    or
    Authorization:InTune-AuthZ-source    msft_complianceState    EQUALS    True/False
    The administrators working with Intune have set up several "Policies"
    The issue is that I have no way of separating between them.
    Noncompliant clients are supposed to be on a different network then compliant clients so if the status changes to noncompliant it should change the network untill it is compliant and the get back to the correct network. This is a process that should be more or less realtime.
    Is this something that can be achieved using ClearPass with Intune extension v5?
    I have gone through the guide and I find no information related to this.
    Any help would be greatly appreciated.
    Rikard Berg
  • 2.  RE: ClearPass - Intune Compliance State -> Separate between configured policies
    Posted Jun 14, 2021 01:13 PM
    Rikard,
    I don't think the GraphAPI returns this data when the extension is querying InTune for the endpoint data, if it was available then the extension would be able to write it into the endpoint as a custom attribute as it does with other data, which you could then reference in policy.
    Danny Jump
    "Passionate about CPPM"
  • 3.  RE: ClearPass - Intune Compliance State -> Separate between configured policies
    Posted Jun 16, 2021 05:21 AM
    Thanks Danny,
    Then I don't think using Compliance state in the rules is a sensible option if it can prevent users from accessing local resources due to compliance state updates being slow.
    Rikard Berg
