Clearpass intune : HTTP attribute query returned error=404
This thread has been viewed 178 times
  • 1.  Clearpass intune : HTTP attribute query returned error=404
    Posted Oct 26, 2023 04:16 PM
    We currently have an on prem AD that we check based on a computer certificate. We are now working on doing this with Intune devices based on EAP TLS. We use 1 root CA under which the local ad and intune users receive their certificate from another "issuing". Now we get the error 404 back.
    We are using the following authentication source:
    If we do not use role mappings, authentication works, even though we get the same error message. Is this more because clearpass knows our certificate. However, we want to make a distinction here with the following role mapping:
  • 2.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Oct 31, 2023 10:25 AM
    For the Intune Extension you would need the Intune Device ID as CN in your certificate and where you 'blurred' in the extension logs, should appear the Intune Device ID.
    The 404 error suggests that the ID queried in Intune is not the Intune Device ID, or the device is not in the same Intune Instance, or the API permissions are not properly setup in Entra ID.
    Did you configure synchronization to the Endpoint DB as well? And do you see the Endpoint Repository populated with Intune Attributes?
  • 3.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Oct 31, 2023 10:58 AM
    Hello Herman,
    In the extension log that has been blurred we see the "Intune device name" returned
    The endpoint DB has been synced and we see Intune attributes here. So when we look in the enpoints we see intune devices. However, we want to use http authorization mode.
    assuming the device id needs to be configured in the certificate as shown in the clearpass documentation.
    Afbeelding met tekst, schermopname, Lettertype, nummer  Automatisch gegenereerde beschrijving
    when using the source without authentication source, we get the same error.Afbeelding met tekst, schermopname, Lettertype, nummer  Automatisch gegenereerde beschrijving
  • 4.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Nov 01, 2023 12:22 AM
    I had the same issue, had to do two things:
    1) It seems that using a SAN field with the URI including 'IntuneDeviceID://' doesn't work because ClearPass doesn't strip it off. I think ClearPass just wants the actual DeviceID value only.
    I opted to not use the SAN, and just use CN={{DeviceID}} in the SCEP profile.
    2) I am using the 'enableEndpointCache' value and only syncing certain attributes. I was not syncing the attributes that I was trying to populate with the HTTP authz source, so I had to add these.
  • 5.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 12, 2023 08:31 AM
    Hi Skywave,
    we are using the CN only in the SCEP profile, but I get the rlm_eap_tls: certificate does not have X509v3 Subject Alternative Name extension error.
    Erik
  • 6.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 12, 2023 05:20 PM
    Hi Erik,
    I didn't see that issue in our deployment.
    I wonder if you have Certificate Comparison enabled in your TLS authentication method?
    Also we are using EAP-TEAP in our environment,
    Cheers,
    Chris
  • 7.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 13, 2023 04:43 AM
    Yes Compare CN or SAN.
    I'll change it to Compare CN only
  • 8.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 13, 2023 04:50 AM
    Changing to Compare CN only gave me the same error.
  • 9.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 13, 2023 05:29 PM
    Hmm not sure why that would be the case, unless the SAN field is referenced elsewhere in the service, or the HTTP auth source.
    As Herman has suggested, it would be worth getting a partner or TAC involved who can look at the logs and configuration in its entirety.
  • 10.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 14, 2023 02:52 AM
    Ok, I'll create another case... :)
    thanks.
  • 11.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 14, 2023 02:05 AM
    I see the same issues with one of my customers, checked the configuration multiple times (with TAC)
    So working with TAC already but we still have not found what causes this.
    Gerber van Beek
  • 12.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Nov 01, 2023 09:23 AM
    In the extension you should not see a device name, but the Device ID.... if you see a name, there probably is something different in the CN, which the client then sends as the username. With just blurred/obfuscated screenshots it's hard to find what's wrong. Maybe you can work with your Aruba partner or Aruba support as having full access to the screens and log data makes it much easier to find and solve the issue.
    The extension log should look like:
    [2023-11-01T14:15:32.773] [INFO] Intune - [fdd2d322-27fd-4f82-a5da-07eb7142dccf] Request for information received from ::ffff:172.20.123.1.
    [2023-11-01T14:15:33.147] [INFO] Intune - [fdd2d322-27fd-4f82-a5da-07eb7142dccf] Information returned for device fdd2d322-27fd-4f82-a5da-07eb7142dccf.
    Where that Device ID should match what's in Intune:
    And what is the Subject-CN in the certificate:
    If it's different at some point, it probably won't work.
  • 13.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Dec 12, 2023 08:27 AM
    Did you found the solution Ahmet?
    Having the same issue right now.
    Do you use EAP-TLS or EAP-TEAP?
    Erik
  • 14.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Jan 29, 2024 12:24 PM
    Hello Herman,
    When you say "Intune Device ID as CN" is it really mandatory for it to be "DevideID"? Couldn't it be, for example, the IMEI or SERIALNUMBER? In MS documentation, it is not advisable in some cases to use CN={{DeviceId}} ( Use SCEP certificate profiles with Microsoft Intune | Microsoft Learn)
    Thank you
  • 15.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Feb 13, 2024 09:23 AM
    Saw that recommendation as well. You can as well use one of the SAN options, where the URL seems most appropriated, to store the DeviceId. But I have not seen issues with CN={{DeviceId}}'. Bottom line, ClearPass needs to have access to the DeviceId in an (unique) attribute of the certificate.
  • 16.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Feb 14, 2024 06:54 AM
    Can you share what your filter looks like with your HTTP config?
  • 17.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Feb 14, 2024 06:56 AM
    This is what I have:
  • 18.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted May 29, 2024 07:47 AM
    I have the same issue with newly installed devices.
    My logs:
    [2024-05-29T13:13:19.941] [ERROR] Intune - Error searching by id 46aed026-f652-43c1-996d-b9485a835a77.  Request failed with status code 404
    [2024-05-29T13:13:21.182] [INFO] Intune - [46aed026-f652-43c1-996d-b9485a835a77] Request for information received from ::ffff:172.17.0.1.
    [2024-05-29T13:13:21.423] [ERROR] Intune - Error searching by id 46aed026-f652-43c1-996d-b9485a835a77.  Request failed with status code 404
    [2024-05-29T13:13:23.312] [INFO] Intune - [46aed026-f652-43c1-996d-b9485a835a77] Request for information received from ::ffff:172.17.0.1.
    [2024-05-29T13:13:23.507] [ERROR] Intune - Error searching by id 46aed026-f652-43c1-996d-b9485a835a77.  Request failed with status code 404
    [2024-05-29T13:13:26.265] [INFO] Intune - [46aed026-f652-43c1-996d-b9485a835a77] Request for information received from ::ffff:172.17.0.1.
    I don't mind sharing the ID's because they don't exist in our tenant. Neither as Intune ID or Azure ID.
    At this point I have no idea where the Intune extension got the ID for this query..
  • 19.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted May 29, 2024 08:27 AM
    Hi David,
    is your Intune setup right?
    ClearPass Intune error 404 seems like this:
  • 20.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted May 29, 2024 11:28 AM
    Hi Erik,
    The connector work fine for our 4-5k other devices.
    Only the freshly installed ones have issues and that's when I get to see this log in the connector (querying unknown ID's).
    I've checked the Intune entries of these newly installed devices and it doesn't equal their Intune or Azure ID.
    I've entered the ID to see which device it belongs to (Intune and Azure) but no hits either
  • 21.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted May 30, 2024 06:15 AM
    Looked up these fauly id's in the 'Endpoint' database in the ClearPass and found the devices, but the Intune ID that the database has, does not match the Intune ID in Intune.
    Seems like the database for some reason has issues updating (certain) devices
  • 22.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted May 30, 2024 07:36 AM
    I assume you use the Intune Device ID from a field in the client certificate? If so, check in your certificate policy (Intune) what is put in that field, or else where the Intune Device ID is stored... If you see the 404 error for HTTP based lookup, that is independent on what is in the ClearPass Endpoint database. I would find out, and make sure that you have the correct IDs to work with.
    Could it be that you have clients with certificates issued before you made changes to the certificate fields? By default the Entra ID device ID is included in the certificate, not the Intune Device ID.
  • 23.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Jun 19, 2024 06:15 AM
    Edited by DavidB Jun 19, 2024 07:41 AM
    Sorry it took a while to reply.
    We do indeed use the Intune ID, as we use the Extension in combination with a HTTP authZ source, which needs to do lookup based on Intune Device ID. (ClearPass Integration Guide Microsoft InTune (hpe.com) page 24)
    I checked the ClearPass Endpoint database and I can confirm that some devices are present with the wrong Intune ID.
    I suspect a reinstall of the device causes this issue, though I'd expect the extension to update the information automatically?
    I can't find any logs in the Intune extension (6.2.8) that point to an error updating the database.
    The device was reinstalled yesterday and has been trying to connect ever since.
    Any suggestions on why this happens (the info doesn't get updated)? - So I can figure out how this can be prevented
  • 24.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Jun 24, 2024 08:26 AM
    There is two ways for ClearPass to work with Intune data. One is using the Endpoint Repository, and the data synchronized in there, with the recommendation to query the endpoint database by Intune DeviceID (versus default query on client MAC address; which is deprecated). Second is via HTTP, which you seem to have configured, and does not use the endpoint database at all. It's a realtime query.
    If you check the Device ID from the extension logs, can you find the same Device ID as intune Device ID in Intune? The 404 means (in most cases) that there is no device in Intune with the queried Intune Device ID. If you see a mismatch on the synced information in the endpoint database, are you sure that the value that you use is indeed the Intune Device ID? I believe by default in a SCEP request, the Entra ID (AAD) Device ID is used, which looks similar but is different.
  • 25.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Aug 22, 2024 11:36 AM
    Hi - Sorry to dive in, but I have the same issue as everyone.
    I see 404 messages in the intune extension, with messages such as:
    Error searching by id 6677a546-5613-4577-aef5-a4f94ertert2c.  Request failed with status code 404
    If I take '6677a546-5613-4577-aef5-a4f94ertert2c' and search Intune directly, the device is found immediately.
    And to confirm, the Certificate: Subject-CN on the request reads the same.
    The HTTP auth source is configured similarly, with %{Certificate:Subject-CN}
    Therefore, what remains - API permissions ( or anything else?)
    If API permissions, then could you please confirm the the exact permissions needed, as I believe I have everything correct, based upon the Oct 23 documentation, but maybe things have changed, since Microsoft like to do that.
    Any pointers, things to try etc, would be very helpful! Thanks in advance.
  • 26.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Aug 23, 2024 03:59 AM
    That Device ID looks invalid as it should be in UUID format which only has hexadecimal characters. There can't be an 'r' or 't' in it.
    Here's my App registration API permissions for the Intune extension:
  • 27.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Aug 23, 2024 04:38 AM
    Hi - I'm so sorry - I should have said that UUID was made up, as I didn't publish an original one - I just replaced some with random characters (I should have been more careful and replaced them with hex, rather than tapping the keyboard randomly).
    Thank you for the permission list though, mine are a little different, so i'll try those...
  • 28.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Aug 27, 2024 10:09 AM
    Hi - I fixed it from my side - an error which I found by reading the API documentation and finding an anomaly, but hopefully it helps someone else:
    Microsoft allows API queries in several ways - for example:
    GET /devices/{id}
    GET /devices(deviceId='{deviceId}')
    and:
    GET /deviceManagement/managedDevices/{managedDeviceId} (see https://learn.microsoft.com/en-us/graph/api/intune-devices-manageddevice-get?view=graph-rest-1.0) for reference.
    Clearpass uses the last one, managedDeviceId. This made me think - what is the difference between id, deviceId and managedDeviceId
    Basically:
    Id = Object ID in MS Azure, Entra
    DeviceId = Device ID in MS Azure, Entra , or Microsoft Entra Device ID in Microsoft Intune
    managedDeviceId = Intune Device ID in Microsoft Intune
    Essentially, make sure you use the 'Intune Device ID' in the cert, for %{Certificate:Subject-CN}
    Hope that was clear and helped someone.
  • 29.  RE: Clearpass intune : HTTP attribute query returned error=404
    Posted Oct 01, 2024 01:26 PM
    Edited by DavidB Oct 03, 2024 06:46 AM
    About the certificates I would like to point out a contradiction in the HPE Aruba documentation and the Microsoft documentation which creates problem!
    HPE Aruba manual: Microsoft Intune Aruba ClearPass
    Microsoft documentation: Use SCEP certificate profiles with Microsoft Intune | Microsoft Learn
    Page 24 of the manual states:
    If using the Extension in combination as discussed later with a HTTP authZ source which needs to do lookup based on Intune Device ID as following:
    • GET /device/info/id/:intuneId
    Page 28 of the manual states:
    The Device ID can be referenced in either the Subject name or the Subject alternative name in the certificate (see Appendix E for more details).
    Microsoft info states:
    Avoid using {{DeviceId}} for subject name on Windows devices.
    In certain instances, certificate generated with this subject name causes sync with Intune to fail.
    This sync issue happened in our environment!
    We fixed it by sending out new certificates with the {{DeviceId}} in the Subject alternative name and used {{DeviceName}} as Subject Name.
    About the "HTTP attribute query returned error=404"-error:
    We upgraded our environment from 6.10 to 6.12 and the issue stopped! Nothing else changed.
    I cannot explain what caused it.
