Danny,
My comments.... 30K devices should ingest in <3 hours comfortably.... but there could be limits as determined by end-2-end performance of your connectivity, not just limited or as a function of how big/fast your internet connection is to InTune
I'd run the syncupdate on the PUB, if you run this on a SUB after it receives the data and writes to the local DB this write will be proxied to the PUB to complete the actual write
Is the appendix of the note on authZ perf, make a note of that, my recollection from when I initially built this {~5 years back} we we're capable of running circ 200 HTTPs calls / sec... you might need to tweak config for this but it really comes down to the API performance
not as much CPPM constraints.
HTH
Danny Jump
"Passionate about CPPM"
Original Message:
Sent: Mar 05, 2021 02:54 AM
Subject: Clearpass - Intune integration - performance questions
we installed intune extension (V5) on clearpass test-cluster. Before moving to production, we have some questions about performanance.
1) we have about 30.000 devices in Intune, not all are relevant to the scope we need this extension, but it's not possible to select fewer in AAD. But when the extension starts and will perform a full sync , how long will it take? Current test environment only has 11 devices and this takes 2 a 3 seconds to sync. We have a quite big & performant internet connection :)
On the 2nd (subscriber) we have the idea to perform a "syncupdateonly" every 5 a 10minutes, just to have recent info about compliant / non-compliant devices.
2) However, also (real-time) http check is needed, any idea how many requests per second can be done? Clearpass is C3000 (4 servers of which 2 will have the extension installed)
Thx4info!
Danny Bosman (KBC Group BE)
