Clearpass - Intune integration - problem to logon to login.microsoftonline.com
  • 1.  Clearpass - Intune integration - problem to logon to login.microsoftonline.com
    Posted Feb 04, 2021 09:49 AM
    We used the setup as described in the integration guide "Microsoft Intune" V5 (sept 2020)  . We are using a proxy environment that does SSL interception and are not able to logon to "login.microsoftonline.com" .  On AAD, we don't see anything happening, not even in the "sign in" logging.
    Has anyone had similar problems? Is it required to disable ssl interception ?
    The extension installs / starts without problem, but when it tries to connect to MS, it fails :
    [2021-02-04T15:05:00.102] [INFO] Intune - Refreshing devices with updates after Thu Feb 04 2021 15:00:00 GMT+0100 (CET).
    [2021-02-04T15:05:00.102] [INFO] Intune - Getting devices to process...
    [2021-02-04T15:05:00.198] [ERROR] Intune - Error getting device list. Request failed with status code 500
    Folllowed by  : The SSL handshake could not be performed.
    Danny Bosman
  • 2.  RE: Clearpass - Intune integration - problem to logon to login.microsoftonline.com
    Posted Feb 04, 2021 03:07 PM
    Danny {great name btw}..... I've never come across any other customer that has reported an ssl-inspect related issue, that's not to say its not there.
    Putting the extension into DEBUG mode, does it provide any extra insight to the login issue?
    Danny Jump
    "Passionate about CPPM"
  • 3.  RE: Clearpass - Intune integration - problem to logon to login.microsoftonline.com
    Posted Feb 05, 2021 04:38 AM
    Hi Danny,
    after some trial & error, we are able to connect to MS by setting "verifySSLCerts": false & bypassProxy": true . We'll do some more testing with this setup.
    Thx a lot for support & the document you wrote !
    Danny Bosman
