CLEARPASS IPSEC
  • 1.  CLEARPASS IPSEC
    Posted Feb 14, 2020 10:33 PM
    Hi ALL,
    Customer is running Clearpass Cluster of 3 Nodes for past 1 year and has no issues.
    But as per security enhancements Customer would like have IPSEC between Clearpass nodes.
    I would like clarify, As Cluster is formed already is it OK to Bring the IPSEC tunnel or Need to Break the cluster and Bring the IPSEC tunnel and need to form cluster again?
  • 2.  RE: CLEARPASS IPSEC
    MVP GURU
    Posted Feb 17, 2020 08:59 PM
    You should be able to configure the IPSEC tunnels up between nodes without removing them from the cluster.
     Please see the following guide https://support.arubanetworks.com/Documentation/tabid/77/DMXModule/512/Command/Core_Download/Default.aspx?EntryId=33251
  • 3.  RE: CLEARPASS IPSEC
    Posted Feb 18, 2020 08:02 AM
    Thanks a lot
