Clearpass is not setting tunnel-tag to 0 when trying to do dynamic vlan assignments
  • 1.  Clearpass is not setting tunnel-tag to 0 when trying to do dynamic vlan assignments
    Posted Jun 25, 2014 04:32 PM
    I am trying to pass 802.1x dynamic vlan assignment to a Dell Powerconnect 3524.  I have ClearPass set up to pass RADIUS:IETF Tunnel-Type=VLAN, Tunnel-Medium-Type=IEEE-802, and Tunnel-Private-Grp-ID=<VLAN ID>
    However on the switch I get this:
    21-Jan-2001 03:24:57 :%SEC-W-SUPPLICANTUNAUTHORIZED: MAC  was rejected on port 6/e9 because Radius accept message does not contain VLAN ID
    21-Jan-2001 03:24:57 :%AAAEAP-W-RADIUSREPLY: Invalid attribute 65 ignored - tag should be 0
    21-Jan-2001 03:24:57 :%AAAEAP-W-RADIUSREPLY: Invalid attribute 64 ignored - tag should be 0
    I would assume this is talking about RFC 2868, but I see anywhere in Clearpass to force the Tunnel-Tag to 0.
    Help please.
    Dennis
  • 2.  RE: Clearpass is not setting tunnel-tag to 0 when trying to do dynamic vlan assignments
    Posted Jun 30, 2014 05:55 AM
    On some other switch vendors you can specify whether the VLAN should be tagged or untagged under the Tunnel-Private-Group-ID Attribute as follows:
    untagged vlan 100:
    U:100
    tagged vlan 100:
    T:100
    untagged vlan 100 and tagged VLAN 200:
    U:100;T:200
    maybe this is something the Dell switches support??
  • 3.  RE: Clearpass is not setting tunnel-tag to 0 when trying to do dynamic vlan assignments
    Posted Jul 25, 2014 02:14 PM
    Aruba support could not help even though it was something in Aruba that needed changed.  I ended up getting help from Dell.  To set the RFC 2868 tag to 0, you need to enable the Avenda RADIUS dictionary and include in enforcement profile the Avenda-Tag-Id needs to be set to 0.  Once this is done, the switch accepts the other three parameters.
  • 4.  RE: Clearpass is not setting tunnel-tag to 0 when trying to do dynamic vlan assignments
    Posted Dec 03, 2018 05:52 PM
    I recently had this issue on ClearPass 6.7.x, but with a twist. My NAS is a Dell 5548P.
    This solution was what I needed, but when I enabled the Avenda dictionary and set the attribute to '0', I never saw the attribute sent back in access tracker adn authentication still didn't work.
    Upon exporting the Enforcement Policy, I found the following line:
    <Attribute displayValue="0" value="" name="Avenda-Tag-Id" type="Radius:Avenda"/>
    Replacing it with the following and re-importing the enforcemnt policy XML fixed my issue--the attribute was sent along and authentications started working.
    <Attribute displayValue="0" value="0" name="Avenda-Tag-Id" type="Radius:Avenda"/>
  • 5.  RE: Clearpass is not setting tunnel-tag to 0 when trying to do dynamic vlan assignments
    Posted Mar 26, 2019 12:29 PM
