Hi
Yes, I got the same issue and after a TAC case I got the solution to search for the root certificate of the https certificate in the trust list and disable or delete all but the correct one.
It turned out that I had two root certificates with the same common name, but with different validity times active and ClearPass can't handle this situation.
From my knowledge ClearPass can handle two Intermediate CA certificates with the same common name, so I can't understand why the same doesn't work with the root certificates.
Best Regards
Jonas Hammarbäck
MVP 2023, ACCX #1335, ACX-Network Security, Aruba SME, ACMP, ACDP , ACEP, ACSA
Aranya AB
Original Message:
Sent: Dec 01, 2023 11:26 AM
Subject: Clearpass: IVConnector generating certificate errors after assigning public certificate to HTTPS
Is anyone else seeing weirdness in 6.11.6 where assigning a public certificate to HTTPS causes IVConnector to produce certificate verification errors?
IVConnector: Could not verify SSL certificates while sending netevents to Netwatch for URL: https://x.x.x.x/netwatch/netevents<o:p></o:p>
I obfuscated the IP since this is a customer site, but it's weird that IVConnector is using the IP address and not the configured FQDN of the node when sending API requests, if certificate verification is a thing they want to do for Insight.
I haven't seen this behavior before on other boxes, but this is the first box I've had 6.11.6 on. It's a little annoying because it fills the event log on the system (events are several times per minute).
