Clearpass Juniper EX4500 Guest Portal Re-Direct
  • 1.  Clearpass Juniper EX4500 Guest Portal Re-Direct
    Posted Mar 14, 2017 07:23 PM
    I'm working with a customer looking to do wired side re-direct for guest portal on Juniper EX4500 switches to CPPM.  It works ~75% of the time and we've struggled to see why it is failing.
    Is anyone out there trying the same thing and if so what has your experience been?
    Thanks all!!
  • 2.  RE: Clearpass Juniper EX4500 Guest Portal Re-Direct
    Posted Mar 14, 2017 07:25 PM
    What code are you running?
  • 3.  RE: Clearpass Juniper EX4500 Guest Portal Re-Direct
    Posted Mar 15, 2017 08:16 AM
    The EX is running 15.1r5.5 and CPPM is 6.6.4
  • 4.  RE: Clearpass Juniper EX4500 Guest Portal Re-Direct
    Posted Mar 15, 2017 08:35 AM
    There have been some known stability issues with the Junos captive portal code. I suggest you own a case with Juniper.
