Clearpass lab specs AWS
  • 1.  Clearpass lab specs AWS
    Posted Nov 26, 2018 01:40 PM
    Hi!
    I'm setting up a clearpass AWS instance for lab and evaluation mainly. Does any one know if I can deploy a instance with lower specs and it will still work ?
    https://www.arubanetworks.com/techdocs/ClearPass/TechNotes/ClearPass_Policy_Manager_AWS/index.htm#AboutRelease/Overview_Intro.htm%3FTocPath%3D_____1
    This specifies: For C1000V, select m4.large. The recommended AWS instance size is 2CPU and 8GB RAM
    1TB disk minimum.
    A bit pricy to just do labs on. I've deployd lower spec servers in vmware before. But I tried 120GB disk and i booted but web would not load.
    Any idea what would be a good minum spec deployment?
  • 2.  RE: Clearpass lab specs AWS
    Posted Nov 27, 2018 09:00 PM
    if this is just for lab testing/eval of ClearPass, i would recomend just insatlling it on a local server, or even on a laptop running under VMWAre Desktop.
  • 3.  RE: Clearpass lab specs AWS
    Posted Nov 28, 2018 03:08 AM
    It's specificly for evaluating the usecase for running clearpass in AWS. I've already got local installations :)
  • 4.  RE: Clearpass lab specs AWS
    Posted Dec 04, 2018 03:55 AM
    bump.
    Anyone that knows ?
  • 5.  RE: Clearpass lab specs AWS
    Posted Dec 04, 2018 09:05 AM
    There is no functional difference between running ClearPass in AWS vs running in ESXi, Hyper-V or KVM.
    There is no lab size for AWS.
  • 6.  RE: Clearpass lab specs AWS
    Posted Dec 04, 2018 09:37 AM
    Hi Tim!
    Maybe Iḿ doing something wrong but running morph-vm makes the server unusable if the second disk is smaller then 1TB. Not running morph-vm makes the second disk not used. The disk1 the server ships with is to small for use, fills up when trying to patch the server.
    EDIT: ah , you did meen that labvm setup is not supported in the same way in AWS as local ? So 1000 is the smallest supported size ?
  • 7.  RE: Clearpass lab specs AWS
    Posted Dec 04, 2018 09:41 AM
    Correct. There is no lab size for EC2.
  • 8.  RE: Clearpass lab specs AWS
    Posted Dec 04, 2018 09:47 AM
    Thanks Tim, do you know if there is any plans to support this ? I like the portability of running it in AWS for demo and lab.
  • 9.  RE: Clearpass lab specs AWS
    Posted Dec 04, 2018 09:49 AM
    No, there are no plans as it is not functionally any different than existing hypervisors.
