ClearPass - licence utilisation when no MAC address sent by NAS
  • 1.  ClearPass - licence utilisation when no MAC address sent by NAS
    Posted Jan 07, 2015 06:44 PM
    Hi All,
    i've run into an ugly situation where my CPPM Server's are not recording licence count for users of the system.
    This appears to be due to my NAS (F5 APM / Juniper SA/SSG) not sending a MAC address through in the RADIUS requests ( they are just using generic RADIUS with MSCHAP)
    Has anybody else encountered this issue and if so how did you work around it?
    i'm thinking i may need to customise the attributes send somehow so that the MAC address of either the user or NAS is sent to ClearPass.
    This presents another issue, if i force a static MAC address from my VPN device, how can ClearPass accurately track the number of users / endpoints when the authentication is effectively done by 1 device, and as such is only 1 endpoint as far as clearpass is concerned.
    Scott
  • 2.  RE: ClearPass - licence utilisation when no MAC address sent by NAS
    Posted Jan 07, 2015 06:55 PM
    Could you share an export of an Access Tracker event where this occurs?
  • 3.  RE: ClearPass - licence utilisation when no MAC address sent by NAS
    Posted Jan 07, 2015 07:24 PM
    Hi clembo.
    screenshots attached. It seems the issue (according to TAC / Engineering) is the lack of End-Host identifier which is used to track the user in the licence db.
    Scott
  • 4.  RE: ClearPass - licence utilisation when no MAC address sent by NAS
    Posted Jan 07, 2015 07:29 PM
    Time Message
    2015-01-08 11:25:30,576 [Th 135 Req 2387140 SessId R00246cc4-20-54adce7a] INFO RadiusServer.Radius - rlm_service: Starting Service Categorization - 105:75:CID
    2015-01-08 11:25:30,581 [Th 135 Req 2387140 SessId R00246cc4-20-54adce7a] INFO RadiusServer.Radius - rlm_service: The request has been categorized into service "AD-Auth-Service"
    2015-01-08 11:25:30,581 [Th 135 Req 2387140 SessId R00246cc4-20-54adce7a] INFO RadiusServer.Radius - rlm_ldap: searching for user <USERNAME> in AD:<WINDOWS DOMAIN>
    2015-01-08 11:25:30,581 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774289 h=607 r=R00246cc4-20-54adce7a] INFO Core.ServiceReqHandler - Service classification result = AD-Auth-Service
    2015-01-08 11:25:30,584 [Th 135 Req 2387140 SessId R00246cc4-20-54adce7a] INFO RadiusServer.Radius - rlm_ldap: found user <USERNAME> in AD:<WINDOWS DOMAIN>
    2015-01-08 11:25:30,584 [Th 135 Req 2387140 SessId R00246cc4-20-54adce7a] INFO RadiusServer.Radius - rlm_ldap: authenticating "<USERNAME>"
    2015-01-08 11:25:30,602 [Th 135 Req 2387140 SessId R00246cc4-20-54adce7a] INFO RadiusServer.Radius - rlm_ldap: user <USERNAME> authenticated succesfully
    2015-01-08 11:25:30,602 [Th 135 Req 2387140 SessId R00246cc4-20-54adce7a] INFO RadiusServer.Radius - rlm_policy: Starting Policy Evaluation.
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] WARN Common.MacAddrAttrProvider - HostMac missing, not populating different mac representations
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO TAT.TagAttrTableUtil - buildTagAttrTableInput: Connection:Client-Mac-Address is not found
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO Common.TagDefinitionCacheTable - No InstanceTagDefCacheMap found for instance id = 3014 entity id = 29
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO Common.TagDefinitionCacheTable - Building the TagDefMapTable for NAD instance=3014
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO Common.TagDefinitionCacheTable - Built 0 tag(s) for NAD instanceId=3014|entityId=29
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO TAT.TagAttrHolderBuilder - No tags built for instanceId=3014|entity=Device
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO TAT.AluTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL AuthLocalUser)
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO TAT.GuTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL GuestUser)
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO TAT.EndpointTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Endpoint)
    2015-01-08 11:25:30,604 [RequestHandler-1-0x7f33d33b9700 r=psauto-1417832412-4774290 h=655 r=R00246cc4-20-54adce7a] INFO TAT.OnboardTagAttrHolderBuilder - buildAttrHolder: Tags cannot be built for instanceId=0 (NULL Onboard Device User)
    2015-01-08 11:25:30,605 [RequestHandler-1-0x7f33d33b9700 h=40582312 c=R00246cc4-20-54adce7a] INFO Core.PETaskScheduler - *** PE_TASK_SCHEDULE_RADIUS Started ***
    2015-01-08 11:25:30,605 [RequestHandler-1-0x7f33d33b9700 h=40582312 c=R00246cc4-20-54adce7a] INFO Core.PETaskScheduler - ** Starting PETaskAuthSourceRestriction **
    2015-01-08 11:25:30,605 [RequestHandler-1-0x7f33d33b9700 h=40582312 c=R00246cc4-20-54adce7a] INFO Core.PETaskScheduler - ** Starting PETaskRoleMapping **
    2015-01-08 11:25:30,605 [RequestHandler-1-0x7f33d33b9700 h=40582313 c=R00246cc4-20-54adce7a] WARN REC.EvaluatorCtx - Prerequisites set is empty, not populating the Request Map
  • 5.  RE: ClearPass - licence utilisation when no MAC address sent by NAS
    Posted Mar 03, 2015 05:00 PM
    So after much waiting i have an answer to this problem. ClearPass only uses the end host identifier attribute to count license utilisation. When this isn't sent by the NAD (such as a firewall / vpn device) then ClearPass can't count the users. Apparently there will be a new licensing model released in 6.5.1 which will correct this issue. Scott
