  • 1.  ClearPass local admin login with SSO enabled
    Posted Jun 24, 2020 01:40 PM
    I have SSO enabled for GuestOperator, but would like to enable for Policy Manager.
    How can I log into Policy Manager with a local admin account when SSO is enabled?
    I am redirected to our SSO sign-in page, of course, so I don't see a way I could use an account local to ClearPass.
    Thanks in advance!
  • 2.  RE: ClearPass local admin login with SSO enabled
    Posted Jun 24, 2020 01:48 PM
    You cannot. You'd have to disable the SSO configuration.
  • 3.  RE: ClearPass local admin login with SSO enabled
    Posted Jun 24, 2020 01:53 PM
    I see. So, if my IDP is down or unreachable for some reason, I am locked out of ClearPass (assuming SSO is enabled for Policy Manager).
  • 4.  RE: ClearPass local admin login with SSO enabled
    Posted Jun 24, 2020 01:57 PM
    Yes, it's no different than any other SP.
  • 5.  RE: ClearPass local admin login with SSO enabled
    Posted Jun 24, 2020 02:01 PM
    Understood. Thanks for the quick reply!
  • 6.  RE: ClearPass local admin login with SSO enabled
    Posted Sep 09, 2024 02:02 PM
    Hello.
    From the CLI, you can enter the following although this will disable sso and you will need to reconfigure partially in the SSO configuration section before it can be used again.
     system sso-reset
    Just learned this from TAC tonight when I got kicked out of my LAB environment.
    Ken
