Can Splunk read CEF or LEEF format of syslog? That has field information included, so should be easy to parse.
There is a Tech Note on Splunk with ClearPass, but it refers to probably the same deprecated extension. I can't find it in the extension search. The note may have some guidance for setting up syslog, just in case you didn't find the document yet.
Original Message:
Sent: Aug 27, 2024 08:38 AM
Subject: Clearpass logging to Splunk
Good morning,
We are currently using CPPM 6.11.9 and are a splunk cloud customer and using the typical clearpass syslog export filter.
The clearpass data comes into our splunk environment in a raw format so pretty useless. We'd like to be able to do the field extractions using the Clearpass Splunk app but the app is depricated on splunkbase and does not support our versions of CPPM or Splunk. So what are folks using? Are other customers using the depricated Splunk app or some other method?
