ClearPass logging to Splunk missing most fields
  • 1.  ClearPass logging to Splunk missing most fields
    Posted May 06, 2019 01:09 PM
    We are sending our ClearPass logs to Splunk, but it appears that most of the fields that are available in the Access Tracker are not being sent via syslog.
    Is there a way to have ClearPass send full verbose logs from the Access Tracker?  Without most of these fields, the logs are not very helpful.
  • 2.  RE: ClearPass logging to Splunk missing most fields
    Posted May 06, 2019 01:13 PM
    Yes, you could configure the syslog filters, to check and uncheck the once, you want to send and not send accordingly.
    This article below should give you an idea of syslogs and filtering works on clearpass:
    Integrating ClearPass Policy Manager and Splunk - HPE Support Center
    hope this helps
  • 3.  RE: ClearPass logging to Splunk missing most fields
    Posted May 06, 2019 01:35 PM
    Thank you.  This is exactly what I was looking for.
  • 4.  RE: ClearPass logging to Splunk missing most fields
    Posted May 06, 2019 01:52 PM
    Happy to be able to help !!
  • 5.  RE: ClearPass logging to Splunk missing most fields
    Posted Aug 22, 2019 03:33 PM
    This document is old and the Splunk app is not supported any longer.
    Now that Archsight is no longer an HPE product can someone @ HPE please rewite the Splunk app and get it  Splunk cloud approved?
