Ciao,
Do you know if it's possible to autenticate mac-address using MSSQL when the switch uses EAP-MD5 as protocol?
Evaluate the MAC address during the authentication phase. For the authentication phase, do an Allow All MAC Auth.
Not the [EAP MD5] ???
If the switch can only do EAP-MD5, you'll need to do this workaround.
Attachment(s)
Thanks Tim
However now I've this error regarding authorization. I attach the logs and SQL cfg
1) Your query for MAC address should be %{Connection:Client-Mac-Address} instead of username
2) Does the query work when you test in the attribute builder?
