Clearpass mac authentication takes too long
This thread has been viewed 52 times
  • 1.  Clearpass mac authentication takes too long
    Posted Jul 27, 2022 10:26 AM
    Hello
    I have a problem with Aruba ClearpassPM. 6.10
    I configured mac-Authentification for Igel Thin Client and the Authentification takes a very long time.3 to 5 minutes. Same after reboot.
    But the 802.1 X Wired Access Authentification works normally.
    What am I doing wrong?
    Thanks.
    David
  • 2.  RE: Clearpass mac authentication takes too long
    Posted Jul 27, 2022 11:22 AM
    If this is wireless, every time you connect a device you need to do a "aaa user delete mac <mac address of device>" or delete the client using the trash can in the GUI of the MM to remove it from the user table.  If you do not do that, a user will stay in the user table for up to 5 minutes and will not attempt mac authentication, even if you disassociate.
  • 3.  RE: Clearpass mac authentication takes too long
    Posted Jul 27, 2022 11:57 AM
    Hello
    That's not a wireless device, that's normal wired client with Linux. I can only perform Mac-authentification.
    How can I solve this? gives other possibilities ?
    Thks
    David
  • 4.  RE: Clearpass mac authentication takes too long
    Posted Jul 27, 2022 12:09 PM
    Sorry.  I thought you were saying wired authentication works but wireless does not.  What is your switch and switch configuration and do you unplug then plug the device back in to start the reauthentication again?  Have you seen the ClearPass wired policy enforcement document here?  https://asp.arubanetworks.com/downloads/documents/RmlsZTpmMDY3Y2UwYS1lNmZiLTExZWEtYjFjMi0zYmZjN2Y0MzMxNDI%3D
  • 5.  RE: Clearpass mac authentication takes too long
    Posted Jul 27, 2022 01:01 PM
    Hello
    Switch: Aruba CX 6100
    just after restart the Client.
    enforcement is configured and work, only authentification take long long time
    David
  • 6.  RE: Clearpass mac authentication takes too long
    Posted Jul 27, 2022 09:03 PM
    Does access tracker give you any clues?
  • 7.  RE: Clearpass mac authentication takes too long
    Posted Jul 28, 2022 01:13 AM
    Hello
    see output below
    David
  • 8.  RE: Clearpass mac authentication takes too long
    Posted Jul 28, 2022 02:22 AM
    when you look at the access tracker list, do you see multiple auth request for the same device on the same switch port?
    check the time stamps, in addition do you see timeouts for this client in access tracker?
    lastly what switch is sending these MAC auths? are there any timers that can be changed, if the switch is first trying to do dot1x and then MAC auth?
  • 9.  RE: Clearpass mac authentication takes too long
    Posted Jul 28, 2022 03:11 AM
    By default, AOS-CX will first try 802.1X and only if the retries and timeouts are expired, it will fallback to MAC Auth. That seems to match what you see.
    Can you try to enable concurrent onboarding and see if that works better?
