Clearpass MAC bypass before 8021.x with IAP
  • 1.  Clearpass MAC bypass before 8021.x with IAP
    Posted Feb 17, 2019 01:07 PM
    Hello all
    Recently we deployed Clearpass as Radius server. There is some IAPs for wireless. We deployed 802.1x authentication for SSID. It works great. But my question is : Is it possible to deploy Mac-address bypass before 8021.x with the same SSID?
    For example, there is an Apple computer which is not in the domain. I want this device to pass authentication without 8021.x if the mac address is in the Static Host List.
    Any help would be appreciated,
    Thank you
  • 2.  RE: Clearpass MAC bypass before 8021.x with IAP
    Posted Feb 17, 2019 01:47 PM
    You would use the MAC address as part of authorization to deny the request.
  • 3.  RE: Clearpass MAC bypass before 8021.x with IAP
    Posted Feb 17, 2019 02:58 PM
    Hello Mr Cappalli
    My point is here not to block by mac address. I want some specific device which is in the static host list, to connect without domain username password.
  • 4.  RE: Clearpass MAC bypass before 8021.x with IAP
    Posted Feb 17, 2019 04:13 PM
    No, this is not possible. You cannot mix encrypted and unencrypted on the same SSID by standard.
  • 5.  RE: Clearpass MAC bypass before 8021.x with IAP
    Posted Feb 18, 2019 05:43 AM
     thank you for your response.
    If I am not mistaken, it is possible with wired solution. For example, IP telephones can pass authentication with mac-address and computer which is connected to ip telephone can pass with 802.1x. I wondered that if there is same solution with wireless.
    But it is not possible as you said, we should use one SSID for 802.1x, one SSID for MAC-auth, right?
  • 6.  RE: Clearpass MAC bypass before 8021.x with IAP
    Posted Feb 18, 2019 09:20 AM
    Correct.
