Clearpass Make Subscriber Fail
This thread has been viewed 35 times
  • 1.  Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 11:36 AM
    I have two clearpass servers on two different subnets. I am trying to convert one to a subscriber. Does it matter that they are in different subnets? If not, what could be the reason for failure? I have already doublechecked the cluster password and time.
    Thanks Guys!
  • 2.  RE: Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 11:49 AM
    Yes, they can be on different subnets, but you cannot create VRRP between them.    Be sure that SSH and HTTPS are allowed between the two servers.
  • 3.  RE: Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 11:50 AM
    I figured. Thanks for clarifying.
    Double checked and nothing is block.
  • 4.  RE: Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 12:02 PM
    Is it giving you an error messages?
  • 5.  RE: Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 12:09 PM
    No error code just a simple message.
    Make subscriber failed
    Adding node as subscriber to 10.80.20.65's cluster...
    Enter Publisher Password:
    Setting up local machine as a subscriber to 10.80.20.65
    ERROR - Setting up subscriber failed
  • 6.  RE: Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 02:07 PM
    Make sure you set the cluster password in the sever settings, change cluster password.
  • 7.  RE: Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 02:27 PM
    Thanks tarnold. This was the first thing I checked.
  • 8.  RE: Clearpass Make Subscriber Fail
    Posted Sep 26, 2013 02:30 PM
    There is a document on the suppot site on firewall setting. I would double check that you have all the ports unblocked.
  • 9.  RE: Clearpass Make Subscriber Fail
    Posted Jul 12, 2014 05:18 PM
    Same issue...firewall was blocking the ports.  Thanks for the help!
  • 10.  RE: Clearpass Make Subscriber Fail
    Posted Aug 22, 2014 10:45 AM
    Old topic with another solution.
    I inherited a situation just like this. The solution was the servers had to be running the same version.
  • 11.  RE: Clearpass Make Subscriber Fail
    Posted Aug 25, 2014 10:30 AM
    in newer versions it tells you that:
    ERROR - 192.168.15.24: - Product version mismatch. Subscriber version=6.3.0.60730, publisher version=6.3.4.64924
