ClearPass manual Cluster Failover - resore process
  • 1.  ClearPass manual Cluster Failover - resore process
    Posted Jan 14, 2016 08:29 PM
    I've been configuring a ClearPass cluster without automatic failover, and I'm curious to know the correct process for restoring to the original state following a manual failover...
    CP1 = Publisher
    CP2 = Subscriber
    Scenario: CP1 fails (data centre gets hit by an asteroid) and CP2 is manually promoted to Publisher.
    What is the correct way to eventually rebuild CP1 and re-add to the cluster as Publisher, without loosing any configuration changes that have been made while CP2 has been Publisher?
    I'm guessing the following?
    1) Re-add CP1 as subscriber to CP2
    2) Shutdown CP2
    3) Promote CP1 to subscriber
    4) Reset database on CP2 and make subscriber to CP1
  • 2.  RE: ClearPass manual Cluster Failover - resore process
    Posted Jan 14, 2016 11:31 PM
    Chris,
    Did you read my CPPM Clustering TechNote, page 44-45 covers what you need to do.
    But basically.....
    • on CP2 you likely have to force drop the CP1 node
    • on CP1 in the cli 'cluster reset-database'
    • reload CP1
    • re-add CP1 node to cluster
    • then after they have sync'd you'll have to promote the nodes as required.
