Clearpass Maximum Number of Concurrent Guest sessions
  • 1.  Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 13, 2017 09:12 AM
    Hi @ all,
    we have a costumer with a big even hall (about 40 000 guests), he wants clearpass for the wifi guest authentication.
    The questions is what is the maximum number of concurrent guest sessions on one clearpass server?
    What´s about a cppm cluster?
    Thanks.
  • 2.  RE: Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 13, 2017 09:17 AM
    It's all based on number of devices. A cluster of two CP-5Ks, for example, can support 10,000 device authentications when requests are load balanced across the cluster.
    We also have High Capacity Guest mode that will double that number for use in guest environments where EAP-based authentication is not required (with the exception of EAP-PEAP-Public).
    http://www.arubanetworks.com/techdocs/ClearPass/Aruba_DeployGd_HTML/Content/5%20Cluster%20Deployment/High_capacity_guest.htm
  • 3.  RE: Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 13, 2017 09:22 AM
    ok, cann a 25k clearpass manage 25000 concurrent guest sessions?
    in high capacity guest mode 50k?
    I think the problem is in this event center, when there is an even and there is a break between the event everyone connect to the wifi, can clearpass handle this?
  • 4.  RE: Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 13, 2017 09:24 AM
    Yes, they're QA tested for appliance size.
  • 5.  RE: Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 13, 2017 09:41 AM
    I´m I right?
    The 25k clearpass can authenticate 25k guests at the same time?
  • 6.  RE: Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 13, 2017 09:44 AM
    ~250 authentications per second. Most of the limitations lie at the
    controller doing the redirect.
  • 7.  RE: Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 14, 2017 03:44 AM
    ok, thanks and what is the max numers the different controllers can handle, do you have an overview?
  • 8.  RE: Clearpass Maximum Number of Concurrent Guest sessions
    Posted Feb 14, 2017 05:54 AM
    There's no hard limit.
