Have you completed the Identity > SSO SP Configuration?
Enabled SSO for Guest Operators?
And Created an Azure based Aruba Application Authorization Service?
If my post was useful, please Accept Solution and Give Kudos.
Zak Chalupka
Principal Engineer - HPE Aruba
ACDX | ACMP | ACSP | ACCP
wifizak@hpe.com------------------------------
Ideas expressed here are solely my own and not necessarily that of HPE Aruba.
Original Message:
Sent: Mar 17, 2024 04:30 AM
Subject: Clearpass & Microsoft Entra ID LDAP integration
Hi All,
Here is my setup
User/Guest <-> AP <-> Aruba-Central <-> O365 LDAP.
Problem:
Clearpass integration is done with Microsoft Entra ID LDAP, and Guest page is also created. However, When I do Sponsor login to authenticate Guest registration it is failing.
Connection test is Successfull
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/07b7d4c3610b47f9b049343891e3102e.png)
Summary page:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/e99301d98bde402d9e59339f22c1200c.png)
Logs:
![](https://higherlogicdownload.s3.amazonaws.com/HPE/MessageImages/a8a4169b21984fe98629588c3abd50b2.png)
Not sure why request is going to Local server- where it is suppose to go to AD. Plz help
Ashwin
