ClearPass morph-vm command
  • 1.  ClearPass morph-vm command
    Posted Jun 25, 2014 12:03 AM
    Hi All,
    I'm looking at options for converting an EVAL-VM to a production VA-5K appliance.
    I found the commands to do this but wanted to find out if there are any risks / considerations in doing this or if there is a process to do this.
    It looks pretty straight forward but just want to double check.
    [appadmin@matrixcppm.cppm.local]# system morph-vm CP-VA-5K
    WARN: VM will be morphed to CP-VA-5K. Once initiated
    you cannot revert to the existing version CP-SW-EVAL.
    All services will be stopped and a reboot initiated to complete
    this operation.
    Press 'y' or 'Y' to proceed: n
    ERROR: Aborting on user request
  • 2.  RE: ClearPass morph-vm command
    Posted Jun 25, 2014 12:07 AM
    It is strait forward, just make sure you VM meets the sizing requirements Ram, Processor, and HD. If it does not then I would create a new VM and backup and restore.
  • 3.  RE: ClearPass morph-vm command
    Posted Jun 25, 2014 12:08 AM
    Thanks Troy!
